Ana içeriğe geç
Mitsubishi T200 Screen Replacement
Neye ihtiyacın var
  1. Mitsubishi T200 Screen Replacement, Screen: adım 1, 2 resimden 1. Mitsubishi T200 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Begin disassembling the phone by removing the phone back cover and battery.
  2. Mitsubishi T200 Screen Replacement: adım 2, 1 resimden 1.
    • To remove the back plate, loosen and remove the four screws by using a #00 Philips head screwdriver.
  3. Mitsubishi T200 Screen Replacement: adım 3, 1 resimden 1.
    • Separate the front plastic component from the motherboard component.
  4. Mitsubishi T200 Screen Replacement: adım 4, 1 resimden 1.
    • Take the circuit board off the motherboard.
  5. Mitsubishi T200 Screen Replacement: adım 5, 2 resimden 1. Mitsubishi T200 Screen Replacement: adım 5, 2 resimden 2.
    • Unclip the four clips to remove the screen (connected to the clear plastic) from the circuit board.
  6. Mitsubishi T200 Screen Replacement: adım 6, 2 resimden 1. Mitsubishi T200 Screen Replacement: adım 6, 2 resimden 2.
    • Remove the attached ribbon from the circuit board by prying open the gray plastic clip at the top right of the circuit board.
  7. Mitsubishi T200 Screen Replacement: adım 7, 2 resimden 1. Mitsubishi T200 Screen Replacement: adım 7, 2 resimden 2.
    • We can now insert the new screen and reassemble the device.
    • Place the ribbon of the new screen into the clip on the top right of the circuit board.
  8. Mitsubishi T200 Screen Replacement: adım 8, 1 resimden 1.
    • Clip the new screen onto the circuit board.
  9. Mitsubishi T200 Screen Replacement: adım 9, 1 resimden 1.
    • Replace circut board back on top of motherboard.
  10. Mitsubishi T200 Screen Replacement: adım 10, 1 resimden 1.
    • Take the entire internal assembly and join it with the front plastic housing.
    • Ensure that the tops of both pieces clip into place before joining the bottom ones.
  11. Mitsubishi T200 Screen Replacement: adım 11, 1 resimden 1.
    • Join the phone's face assembly to the back plastic housing. Make sure you carefully insert the front into the antenna's clip first.
    • Snap the whole unit together.
  12. Mitsubishi T200 Screen Replacement: adım 12, 1 resimden 1.
    • Firmly replace screws into the backing.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Taylor Lewis
14 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Meza Spring 2014 Ohio State, Team 1-5, Meza Spring 2014 üyesi
OSU-MEZA-S14S1G5
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 838
