Ana içeriğe geç
Mitsubishi VLT-HC3800LP Bulb Replacement
Neye ihtiyacın var
  1. Mitsubishi VLT-HC3800LP Bulb Replacement, Bulb: adım 1, 1 resimden 1.
    • Remove both screws as shown and gently pull the metallic frame. It is anchored on two small notches on the other side.
  2. Mitsubishi VLT-HC3800LP Bulb Replacement: adım 2, 3 resimden 1. Mitsubishi VLT-HC3800LP Bulb Replacement: adım 2, 3 resimden 2. Mitsubishi VLT-HC3800LP Bulb Replacement: adım 2, 3 resimden 3.
    • Remove both screws onn the handle side, and both dark screws on the opposite side.
    • Slightly pull the metal frame (1) and lift the housing top half (2) to reveal the bulb.
  3. Mitsubishi VLT-HC3800LP Bulb Replacement: adım 3, 3 resimden 1. Mitsubishi VLT-HC3800LP Bulb Replacement: adım 3, 3 resimden 2. Mitsubishi VLT-HC3800LP Bulb Replacement: adım 3, 3 resimden 3.
    • Remove the black stickers hiding both screws that will have to be removed in this step.
  4. Mitsubishi VLT-HC3800LP Bulb Replacement: adım 4, 1 resimden 1.
    • Lift the bulb and its holder from the housing frame.
    • It will then be easier to disconnect the cables
  5. Mitsubishi VLT-HC3800LP Bulb Replacement: adım 5, 3 resimden 1. Mitsubishi VLT-HC3800LP Bulb Replacement: adım 5, 3 resimden 2. Mitsubishi VLT-HC3800LP Bulb Replacement: adım 5, 3 resimden 3.
    • Remove the 4 screws and gently lift the frame maintaining the bulb.
    • Note the two notches which will only allow one way to mount the frame.
    • Note the bulb's contacts orientation.
    • Handle the replacement bulb with extreme care. Avoid touching it with bare hands. Bulbs don't like fingerprints at all!
  6. Mitsubishi VLT-HC3800LP Bulb Replacement: adım 6, 1 resimden 1.
    • Done!
    • Put the lamp back in place according to your projector's user manual.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
ralf
333 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Did my Mitsubishi HC4000 today with lamp only..Found this after the event but useful anyway!
swingmanic - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 16
Her zaman: 8,697
