Giriş
Use this guide to install a new power supply.
Neye ihtiyacın var
Remove the following 8 Phillips #1 screws:
One 22 mm Phillips #1 in the bottom right corner of the back panel.
One 18 mm Phillips #1 in the top middle of the back panel.
Six 18 mm Phillips #1 in the rest of the back panel.
Remove the four 10 mm black Phillips #1 screws with fine thread that attach the protective case to the TV.
Bir başkası bu kılavuzu tamamladı.
