Ana içeriğe geç
  1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade Cover: adım 1, 3 resimden 1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade Cover: adım 1, 3 resimden 2. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade Cover: adım 1, 3 resimden 3.
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • If the clear water pump hose is connected, remove it now.
    • Loosen the plastic knob holding the saw's cutting head in place.
    • Lower the cutting head while keeping it steady.
  2. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 2, 2 resimden 1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 2, 2 resimden 2.
    • Unscrew the knob.
    • Remove it from the cutting head.
  3. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 3, 2 resimden 1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 3, 2 resimden 2.
    • Loosen the plastic knob holding the blade cover in place.
  4. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 4, 3 resimden 1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 4, 3 resimden 2. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 4, 3 resimden 3.
    • Loosen the wing nut on the blade cover pivot shaft.
    • Remove the wing nut and accompanying washer.
  5. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 5, 2 resimden 1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 5, 2 resimden 2.
    • Pivot the blade cover up and pull it off the shaft.
  6. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade: adım 6, 3 resimden 1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade: adım 6, 3 resimden 2. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade: adım 6, 3 resimden 3.
    • Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
    • Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
  7. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 7, 2 resimden 1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 7, 2 resimden 2.
    • Remove the hex nut.
    • Remove the outer flange.
  8. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 8, 2 resimden 1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 8, 2 resimden 2.
    • Remove the cutting blade.
    • The blade can be sharp, so handle with care.
  9. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Cutting Head: adım 9, 3 resimden 1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Cutting Head: adım 9, 3 resimden 2. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Cutting Head: adım 9, 3 resimden 3.
    • Pull the entire cutting head straight off the shaft holding it in place.
  10. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Bottom Cover: adım 10, 1 resimden 1.
    • Remove the eight Phillips #2 screws on the underside of the cutting head.
  11. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 11, 2 resimden 1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: adım 11, 2 resimden 2.
    • Remove the bottom cover.
Sonuç
Carsten Frauenheim
82.502 İtibar
330 adet Kılavuz yazıldı
iFixit iFixit üyesi
Community
139 Üyeler
15.812 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 121
