Ana içeriğe geç
Modal MD-SPBT01 LED Light Wiring Replacement
Neye ihtiyacın var
  1. Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: adım 1, 2 resimden 1. Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: adım 1, 2 resimden 2.
    • Use your plastic opening tool to pry the metal speaker cover off.
  2. Modal MD-SPBT01 LED Light Wiring Replacement: adım 2, 1 resimden 1.
    • You can now use the Phillips #00 screwdriver to remove the four screws.
  3. Modal MD-SPBT01 LED Light Wiring Replacement: adım 3, 1 resimden 1.
    • With the screws removed, you can now remove the top piece of the speaker to gain access to the interior.
  4. Modal MD-SPBT01 LED Light Wiring Replacement: adım 4, 1 resimden 1.
    • Locate the LED wire connection and remove it from the mother board.
    • To make replacing the LED wiring easier, remove the speaker wire to fully disconnect the speaker from the mother board.
  5. Modal MD-SPBT01 LED Light Wiring Replacement: adım 5, 1 resimden 1.
    • Now you can remove the wiring from the speaker side of the device.
    • It might take a bit of work to remove the wires because they are glued down on this side.
  6. Modal MD-SPBT01 LED Light Wiring Replacement: adım 6, 1 resimden 1.
    • Now with the LED wiring removed, a new wire can be installed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathan Hall
258 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 641
