Ana içeriğe geç
Modal MD-SPBT01 Speaker Wiring Replacement
Neye ihtiyacın var
  1. Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: adım 1, 2 resimden 1. Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: adım 1, 2 resimden 2.
    • Use the plastic opening tool to pull the metal cover off the top of the speaker.
  2. Modal MD-SPBT01 Speaker Wiring Replacement: adım 2, 1 resimden 1.
    • Remove the four screws that are inside the holes on the top of the speaker.
    • Use a Phillips 00 screwdriver to remove the 10mm screws.
  3. Modal MD-SPBT01 Speaker Wiring Replacement: adım 3, 1 resimden 1.
    • Pull the top piece of the speaker off to allow access to the interior.
  4. Modal MD-SPBT01 Speaker Wiring Replacement: adım 4, 1 resimden 1.
    • Locate the speaker wire connection and remove the wiring.
    • Locate the LED lighting wire and remove that as well.
  5. Modal MD-SPBT01 Speaker Wiring Replacement: adım 5, 1 resimden 1.
    • Once you disconnect the wires, you can remove the speaker.
  6. Modal MD-SPBT01 Speaker Wiring Replacement: adım 6, 2 resimden 1. Modal MD-SPBT01 Speaker Wiring Replacement: adım 6, 2 resimden 2.
    • Remove the positive and negative connections for the wiring to fully disconnect the wire.
    • Now that you have removed the defective wiring, you can install a new one.
Sonuç
Nathan Hall
258 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 508
