Ana içeriğe geç
Modal MD-WORCSS6 Battery Replacement
Neye ihtiyacın var
    1. Modal MD-WORCSS6 Battery Replacement, Modal MD-WORCSS6 Teardown Guide: adım 1, 2 resimden 1. Modal MD-WORCSS6 Battery Replacement, Modal MD-WORCSS6 Teardown Guide: adım 1, 2 resimden 2.
      • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
      • Using the jimmy tool, carefully pry off the black plastic ring.
      • Remove the spring assembly from inside the transparent plastic tube.
      FixBot'a Sor
      Yorum Ekle
    2. Modal MD-WORCSS6 Battery Replacement: adım 2, 2 resimden 1. Modal MD-WORCSS6 Battery Replacement: adım 2, 2 resimden 2.
      • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
      • Take the plastic tube off of the metal casing.
      FixBot'a Sor
      Yorum Ekle
    3. Modal MD-WORCSS6 Battery Replacement: adım 3, 2 resimden 1. Modal MD-WORCSS6 Battery Replacement: adım 3, 2 resimden 2.
      • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
      • With the button assembly removed, slide off the metal casing.
      FixBot'a Sor
      Yorum Ekle
    4. Modal MD-WORCSS6 Battery Replacement: adım 4, 3 resimden 1. Modal MD-WORCSS6 Battery Replacement: adım 4, 3 resimden 2. Modal MD-WORCSS6 Battery Replacement: adım 4, 3 resimden 3.
      • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
      • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
      FixBot'a Sor
      Yorum Ekle
    5. Modal MD-WORCSS6 Battery Replacement: adım 5, 3 resimden 1. Modal MD-WORCSS6 Battery Replacement: adım 5, 3 resimden 2. Modal MD-WORCSS6 Battery Replacement: adım 5, 3 resimden 3.
      • Carefully peel the tape off far enough to remove the 3 batteries.
      FixBot'a Sor
      Yorum Ekle
    1. Modal MD-WORCSS6 Battery Replacement, Battery: adım 6, 1 resimden 1.
      • Replace the batteries by pulling them out of their holder and putting new ones in the same places.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Where do you get the replacement batteries?
Gerry David - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 1,650
