Ana içeriğe geç
Modal Rechargeable Wine Opener Power Button Replacement
Neye ihtiyacın var
  1. Modal Rechargeable Wine Opener Power Button Replacement, Modal Rechargeable Wine Opener power button: adım 1, 1 resimden 1.
    • Carefully place the spudger under the black cylindrical ring and pry it off the top.
  2. Modal Rechargeable Wine Opener Power Button Replacement: adım 2, 1 resimden 1.
    • Remove the spring
    • Remove the spring guide as well to obtain clear access to the screws
  3. Modal Rechargeable Wine Opener Power Button Replacement: adım 3, 3 resimden 1. Modal Rechargeable Wine Opener Power Button Replacement: adım 3, 3 resimden 2. Modal Rechargeable Wine Opener Power Button Replacement: adım 3, 3 resimden 3.
    • Remove all four 4mm screws with a J1 Screwdriver
    • Remove the clear cylindrical cap
  4. Modal Rechargeable Wine Opener Power Button Replacement: adım 4, 3 resimden 1. Modal Rechargeable Wine Opener Power Button Replacement: adım 4, 3 resimden 2. Modal Rechargeable Wine Opener Power Button Replacement: adım 4, 3 resimden 3.
    • Apply pressure to both of the springs on the surface near the corkscrew, releasing the button port.
  5. Modal Rechargeable Wine Opener Power Button Replacement: adım 5, 3 resimden 1. Modal Rechargeable Wine Opener Power Button Replacement: adım 5, 3 resimden 2. Modal Rechargeable Wine Opener Power Button Replacement: adım 5, 3 resimden 3.
    • Remove the malfunctioning buttons from the plastic frame.
Sonuç
Lauren Spicher
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 15-4, Remmell Spring 2017 USF Tampa, Team 15-4, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S15G4
4 Üyeler
1 Kılavuz yazıldı
4Kılavuz Yorumları
where do you by the replacement switch?
Stan Okumura - Yanıt
are there any posts for fixing the usb charging port?
Cristian Sanabria - Yanıt
If the lights work, the buttons are not the problem. I can get the cork screw to turn manually, but it will not continue run beyond a few tries. Must be the motor.
tom.o@mac.com - Yanıt
Could be also the battery. I will try to change the battery.
Daniel Siegenthaler -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 9,024
