Giriş
If your mouse is intermittently disconnecting, randomly missing movements and inputs - you might have a broken or damaged mouse cable. The mouse cable carries data from the mouse to your computer. A damaged cable can result in missed mouse movements and inputs. Before starting this guide try a different connector (most likely USB) port on your computer, and inspect the connector for dirt and debris.
This guide shows an easy, step-by-step process on how to replace the mouse cable in a Glorious Model O- mouse.
The mouse should be physically unplugged from your computer prior to beginning your repair.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
Turn the mouse over so that the feet are facing you.
Remove the bottom two mouse feet using tweezers.
Route the new cable through the slit in the circuit board.
Route the new cable behind the pillars.
Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
4 farklı kişi bu kılavuzu tamamladı.
