Ana içeriğe geç
Moen Posi-Temp Cartridge Part #1112b Replacement
Neye ihtiyacın var
  1. Moen Posi-Temp Cartridge Part #1112b Replacement, Moen Posi-Temp Cartridge Part #1112b: adım 1, 1 resimden 1.
    • Turn the water shutoff valve counter-clockwise to the "off" position.
  2. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 2, 1 resimden 1.
    • Open both the hot and cold taps of a nearby faucet or shower until the water no longer flows.
  3. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 3, 2 resimden 1. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 3, 2 resimden 2.
    • Turn the handle of the shower valve 180 degrees until it is in the "up" or "on" position.
  4. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 4, 2 resimden 1. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 4, 2 resimden 2.
    • Unscrew the handle screw with an Allen wrench.
    • Remove the handle.
  5. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 5, 2 resimden 1. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 5, 2 resimden 2.
    • Remove the handle adaptor screw with a Phillips screwdriver.
    • Remove the handle adaptor simply by pulling it out.
  6. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 6, 1 resimden 1.
    • Pull out the white key/adjustable limit stop.
  7. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 7, 3 resimden 1. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 7, 3 resimden 2. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 7, 3 resimden 3.
    • Gently pull out the stop tube.
  8. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 8, 3 resimden 1. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 8, 3 resimden 2. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 8, 3 resimden 3.
    • Using the Phillips head screwdriver, remove the two screws located at the top right corner and bottom left corner.
    • Remove the metal plate.
  9. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 9, 3 resimden 1. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 9, 3 resimden 2. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 9, 3 resimden 3.
    • Slide the tip of needle-nose pliers under the notch of the retaining clip and pull the clip upwards.
  10. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 10, 3 resimden 1. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 10, 3 resimden 2. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 10, 3 resimden 3.
    • Clamp firmly onto the brass tube with a pair of vice grips and gently but firmly pull out the cartridge.
  11. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 11, 2 resimden 1. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 11, 2 resimden 2.
    • Insert the new Moen Posi-Temp cartridge.
  12. Moen Posi-Temp Cartridge Part #1112b Replacement: adım 12, 1 resimden 1.
    • Insert the new cartridge into the valve assembly.
    • Ensure that the H/C symbols are facing up.
    • Ensure that the notch on the brass tube is also facing up.
Sonuç
John Mendoza
205 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 39
Her zaman: 1,142
