Ana içeriğe geç
Monster SoundStage S1 Mini Speaker Replacement
Neye ihtiyacın var
  1. Monster SoundStage S1 Mini Speaker Replacement, Speaker: adım 1, 2 resimden 1. Monster SoundStage S1 Mini Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Remove the speaker wires from the motherboard by pinching the plastic tab at the end of the cable and pulling towards you.
  2. Monster SoundStage S1 Mini Speaker Replacement: adım 2, 2 resimden 1. Monster SoundStage S1 Mini Speaker Replacement: adım 2, 2 resimden 2.
    • Unscrew 1.2 cm Torx security screw, holding the silver circle connector, to disconnect the wire from the speakerboard to the motherboard
  3. Monster SoundStage S1 Mini Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the black putty from the speaker wires at both ends of the speaker board.
  4. Monster SoundStage S1 Mini Speaker Replacement: adım 4, 3 resimden 1. Monster SoundStage S1 Mini Speaker Replacement: adım 4, 3 resimden 2. Monster SoundStage S1 Mini Speaker Replacement: adım 4, 3 resimden 3.
    • Solder the black plastic encasing the red and black wires.
  5. Monster SoundStage S1 Mini Speaker Replacement: adım 5, 2 resimden 1. Monster SoundStage S1 Mini Speaker Replacement: adım 5, 2 resimden 2.
    • Remove both the black and red wires with pliers
    • Pliers may stick to speaker because it is magnetic.
  6. Monster SoundStage S1 Mini Speaker Replacement: adım 6, 2 resimden 1. Monster SoundStage S1 Mini Speaker Replacement: adım 6, 2 resimden 2.
    • Tuck wires through the hole where the speaker is located, then gently push the speaker out.
    • The 1.2 cm Torx security screws that stayed in place near the speaker will now fall out.
    • To remove the other speaker repeat steps 3-6
Sonuç
Bir başkası bu kılavuzu tamamladı.
Heather Carrillo
412 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-6, Bruce Fall 2016 CSU Fullerton, Team 2-6, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S2G6
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 497
