Ana içeriğe geç
Monster Soundstage S2 Rear Speaker Replacement
Neye ihtiyacın var
  1. Monster Soundstage S2 Rear Speaker Replacement, Speaker Grille: adım 1, 2 resimden 1. Monster Soundstage S2 Rear Speaker Replacement, Speaker Grille: adım 1, 2 resimden 2.
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Rear Speaker Replacement: adım 2, 3 resimden 1. Monster Soundstage S2 Rear Speaker Replacement: adım 2, 3 resimden 2. Monster Soundstage S2 Rear Speaker Replacement: adım 2, 3 resimden 3.
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Rear Speaker Replacement: adım 3, 1 resimden 1.
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Rear Speaker Replacement: adım 4, 3 resimden 1. Monster Soundstage S2 Rear Speaker Replacement: adım 4, 3 resimden 2. Monster Soundstage S2 Rear Speaker Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Rear Speaker Replacement: adım 5, 2 resimden 1. Monster Soundstage S2 Rear Speaker Replacement: adım 5, 2 resimden 2.
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Rear Speaker Replacement: adım 6, 2 resimden 1. Monster Soundstage S2 Rear Speaker Replacement: adım 6, 2 resimden 2.
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Rear Speaker Replacement: adım 7, 3 resimden 1. Monster Soundstage S2 Rear Speaker Replacement: adım 7, 3 resimden 2. Monster Soundstage S2 Rear Speaker Replacement: adım 7, 3 resimden 3.
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Rear Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the front speaker grille.
  9. Monster Soundstage S2 Rear Speaker Replacement, Front Speakers: adım 9, 3 resimden 1. Monster Soundstage S2 Rear Speaker Replacement, Front Speakers: adım 9, 3 resimden 2. Monster Soundstage S2 Rear Speaker Replacement, Front Speakers: adım 9, 3 resimden 3.
    • After removing grille, you will see the speakers.
    • Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
  10. Monster Soundstage S2 Rear Speaker Replacement: adım 10, 2 resimden 1. Monster Soundstage S2 Rear Speaker Replacement: adım 10, 2 resimden 2.
    • Carefully lift each speaker from the housing. It may be necessary to break a light adhesive seal.
    • Be aware of the two wires that are connected to each speaker.
    • Set each speaker beside the main housing.
  11. Monster Soundstage S2 Rear Speaker Replacement: adım 11, 3 resimden 1. Monster Soundstage S2 Rear Speaker Replacement: adım 11, 3 resimden 2. Monster Soundstage S2 Rear Speaker Replacement: adım 11, 3 resimden 3.
    • Carefully but firmly unplug the two wires from each driver.
    • The front speakers can now be removed.
  12. Monster Soundstage S2 Rear Speaker Replacement, Front Panel: adım 12, 2 resimden 1. Monster Soundstage S2 Rear Speaker Replacement, Front Panel: adım 12, 2 resimden 2.
    • Identify the eight screws around the border of the front panel.
    • Using the TR 10 driver, remove the two 8mm screws.
    • Using the TR 10 driver, remove the six 12mm screws.
  13. Monster Soundstage S2 Rear Speaker Replacement: adım 13, 1 resimden 1.
    • Use a 5 mm hex driver to extend the TR 10 driver. This allows the driver to access screws with deeper countersinks.
  14. Monster Soundstage S2 Rear Speaker Replacement: adım 14, 2 resimden 1. Monster Soundstage S2 Rear Speaker Replacement: adım 14, 2 resimden 2.
    • Identify the remaining four screws in the front panel.
    • Use the extended driver from the previous step to remove the four 12mm TR 10 screws.
  15. Monster Soundstage S2 Rear Speaker Replacement: adım 15, 2 resimden 1. Monster Soundstage S2 Rear Speaker Replacement: adım 15, 2 resimden 2.
    • Gently pull the front panel away from the back panel.
    • There are wires that connect the front and back panels. The two sides can be safely folded away from each other and laid flat on the table.
    • Remove the white sound dampening material from the speaker. Note the location of the material and set aside.
  16. Monster Soundstage S2 Rear Speaker Replacement, Rear Speaker: adım 16, 2 resimden 1. Monster Soundstage S2 Rear Speaker Replacement, Rear Speaker: adım 16, 2 resimden 2.
    • Remove the four 10mm screws that secure the rear speaker with a TR 10 driver.
    • Remove the rear speaker from the housing.
    • Be careful to not stress or damage the two wires that are connected to the driver.
  17. Monster Soundstage S2 Rear Speaker Replacement: adım 17, 1 resimden 1.
    • Carefully but firmly unplug the two wires from the driver.
    • Remove the rear speaker.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Shaw Hughes
831 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-5, Maness Winter 2017 Cal Poly, Team 21-5, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G5
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 331
