Ana içeriğe geç
Monster Soundstage S2 Speaker Grille Replacement
Neye ihtiyacın var
  1. Monster Soundstage S2 Speaker Grille Replacement, Speaker Grille: adım 1, 2 resimden 1. Monster Soundstage S2 Speaker Grille Replacement, Speaker Grille: adım 1, 2 resimden 2.
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Speaker Grille Replacement: adım 2, 3 resimden 1. Monster Soundstage S2 Speaker Grille Replacement: adım 2, 3 resimden 2. Monster Soundstage S2 Speaker Grille Replacement: adım 2, 3 resimden 3.
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Speaker Grille Replacement: adım 3, 1 resimden 1.
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Speaker Grille Replacement: adım 4, 3 resimden 1. Monster Soundstage S2 Speaker Grille Replacement: adım 4, 3 resimden 2. Monster Soundstage S2 Speaker Grille Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Speaker Grille Replacement: adım 5, 2 resimden 1. Monster Soundstage S2 Speaker Grille Replacement: adım 5, 2 resimden 2.
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Speaker Grille Replacement: adım 6, 2 resimden 1. Monster Soundstage S2 Speaker Grille Replacement: adım 6, 2 resimden 2.
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Speaker Grille Replacement: adım 7, 3 resimden 1. Monster Soundstage S2 Speaker Grille Replacement: adım 7, 3 resimden 2. Monster Soundstage S2 Speaker Grille Replacement: adım 7, 3 resimden 3.
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Speaker Grille Replacement: adım 8, 1 resimden 1.
    • Remove the front speaker grille.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Shaw Hughes
831 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-5, Maness Winter 2017 Cal Poly, Team 21-5, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G5
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 29
Her zaman: 499
