Ana içeriğe geç
Montgomery Ward GEN-39500 Internal Power Supply Replacement
Neye ihtiyacın var
  1. Montgomery Ward GEN-39500 Internal Power Supply Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Internal Power Supply Replacement: adım 2, 1 resimden 1.
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Internal Power Supply Replacement: adım 3, 2 resimden 1. Montgomery Ward GEN-39500 Internal Power Supply Replacement: adım 3, 2 resimden 2.
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Internal Power Supply Replacement, Internal Power Supply: adım 4, 1 resimden 1.
    • Unscrew the six 10 mm Phillips screws holding the mounting plate in place.
  5. Montgomery Ward GEN-39500 Internal Power Supply Replacement: adım 5, 3 resimden 1. Montgomery Ward GEN-39500 Internal Power Supply Replacement: adım 5, 3 resimden 2. Montgomery Ward GEN-39500 Internal Power Supply Replacement: adım 5, 3 resimden 3.
    • Unsolder the wires connecting the power supply unit to the battery container.
  6. Montgomery Ward GEN-39500 Internal Power Supply Replacement: adım 6, 1 resimden 1.
    • Remove the power supply unit.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dustin Platt
931 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-5, Lancaster Spring 2015 Cal Poly, Team 12-5, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G5
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 104
