Ana içeriğe geç
Moosoo XL-618A Battery Replacement
Neye ihtiyacın var
    1. Moosoo XL-618A Battery Replacement, Battery: adım 1, 2 resimden 1. Moosoo XL-618A Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Press on the blue tab to release the battery pack, and pull.
      FixBot'a Sor
      Yorum Ekle
    2. Moosoo XL-618A Battery Replacement: adım 2, 1 resimden 1.
      • Remove each 15 mm screw from the four corners of the battery pack using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Moosoo XL-618A Battery Replacement: adım 3, 2 resimden 1. Moosoo XL-618A Battery Replacement: adım 3, 2 resimden 2.
      • Remove the back piece of the battery.
      FixBot'a Sor
      Yorum Ekle
    4. Moosoo XL-618A Battery Replacement: adım 4, 2 resimden 1. Moosoo XL-618A Battery Replacement: adım 4, 2 resimden 2.
      • Find the wire connecting the battery to the charging port, locate the black tab at the top of the pack and pull the tab out first then the battery.
      • Be careful not to pull the wire out of the battery itself as this will further damage the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kennedy E.
199 İtibar
2 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-1, McMurrin Fall 2023 Utah Tech University, Team 1-1, McMurrin Fall 2023 üyesi
UTAHTECH-MCMURRIN-F23S1G1
3 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 108
Her zaman: 2,018
