Ana içeriğe geç
Moosoo XL-618A Belt Replacement
Neye ihtiyacın var
  1. Moosoo XL-618A Belt Replacement, Motor: adım 1, 1 resimden 1.
    • Remove the eight 11 mm screws on the bottom of the vacuum with the Phillips #1 screwdriver.
  2. Moosoo XL-618A Belt Replacement: adım 2, 3 resimden 1. Moosoo XL-618A Belt Replacement: adım 2, 3 resimden 2. Moosoo XL-618A Belt Replacement: adım 2, 3 resimden 3.
    • Pull the two hard plastic covers off of the floor brush piece.
  3. Moosoo XL-618A Belt Replacement: adım 3, 1 resimden 1.
    • Remove the 9 mm screw to the motor with the Phillips #1 screwdriver.
  4. Moosoo XL-618A Belt Replacement: adım 4, 3 resimden 1. Moosoo XL-618A Belt Replacement: adım 4, 3 resimden 2. Moosoo XL-618A Belt Replacement: adım 4, 3 resimden 3.
    • Take the motor and floor brush out of their slot and pull the floor brush off of the motor.
    • This is the perfect opportunity to clean the brush as well.
  5. Moosoo XL-618A Belt Replacement: adım 5, 3 resimden 1. Moosoo XL-618A Belt Replacement: adım 5, 3 resimden 2. Moosoo XL-618A Belt Replacement: adım 5, 3 resimden 3.
    • Remove the two 9 mm screws with the Phillips #1 screwdriver and pull the plastic piece off of the motor.
  6. Moosoo XL-618A Belt Replacement, Belt: adım 6, 1 resimden 1.
    • Take the plastic piece and pull the belt off of the wheel.
Sonuç
tommygourley
73 İtibar
1 Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-1, McMurrin Fall 2023 Utah Tech University, Team 1-1, McMurrin Fall 2023 üyesi
UTAHTECH-MCMURRIN-F23S1G1
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 47
Her zaman: 753
