Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Morphy Richards Iron cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Morphy Richards Iron Teardown, Morphy Richards Iron Teardown: adım 1, 1 resimden 1.
    • This is the iron we will take apart.
  2. Morphy Richards Iron Teardown: adım 2, 1 resimden 1.
    • First remove the rear or the iron using the flathead screwdriver.
  3. Morphy Richards Iron Teardown: adım 3, 1 resimden 1.
    • Next remove the cable bridge bracket.
  4. Morphy Richards Iron Teardown: adım 4, 1 resimden 1.
    • Next remove the screws from the base. (see arrows for location)
  5. Morphy Richards Iron Teardown: adım 5, 1 resimden 1.
    • Next remove the screw the hold the top on.
  6. Morphy Richards Iron Teardown: adım 6, 1 resimden 1.
    • To free the long cable remove from terminal block at rear.
  7. Morphy Richards Iron Teardown: adım 7, 1 resimden 1.
    • At the front of the iron pull out the buttons for the steam and water.
  8. Morphy Richards Iron Teardown: adım 8, 1 resimden 1.
    • Next unclip the button holder (red circle) by undoing the screws (black circle)
  9. Morphy Richards Iron Teardown: adım 9, 1 resimden 1.
    • Next remove the bridge clip from the arrows position.
  10. Morphy Richards Iron Teardown: adım 10, 1 resimden 1.
    • Next remove the inner button (black circle)
    • Now remove the centre screw (red arrow)
  11. Morphy Richards Iron Teardown: adım 11, 1 resimden 1.
    • slide off the cable holder from the cable.
  12. Morphy Richards Iron Teardown: adım 12, 1 resimden 1.
    • Disassemble the plug
    • First remove the casing.
    • Now remove the wires from the pins.
    • Next remove the pins.
  13. Morphy Richards Iron Teardown: adım 13, 1 resimden 1.
    • Remove front of the iron by undoing the screw (arrow) by first taking off cover cap.
  14. Morphy Richards Iron Teardown: adım 14, 1 resimden 1.
    • Next take out round selector, this is simply clipped so can be pulled out with pliers.
  15. Morphy Richards Iron Teardown: adım 15, 1 resimden 1.
    • Next remove the washer parts at the front of the iron.
    • Take the tubing off.
  16. Morphy Richards Iron Teardown: adım 16, 1 resimden 1.
    • Remove the seals for the water pump.
    • Now take pumps out.
  17. Morphy Richards Iron Teardown: adım 17, 1 resimden 1.
    • Remove the screw (circled) this will lead to the separation of the base and the top.
  18. Morphy Richards Iron Teardown: adım 18, 1 resimden 1.
    • Remove the top of the iron to reveal the under parts.
    • Now remove the rubber seals from the plate.
    • Take out the screws linking to the stainless steel base.
  19. Morphy Richards Iron Teardown: adım 19, 1 resimden 1.
    • Remove the terminal block from the wires.
    • Next take off the black section of the iron.
  20. Morphy Richards Iron Teardown: adım 20, 1 resimden 1.
    • Now remove the screws from the steel base.
  21. Morphy Richards Iron Teardown: adım 21, 1 resimden 1.
    • Next remove each individual part ( mostly wiring)
  22. Morphy Richards Iron Teardown: adım 22, 1 resimden 1.
    • All parts at the end of the process.
RIchard fox
269 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 41
Son 30 gün: 105
Her zaman: 33,619
