Ana içeriğe geç
Motherboard Disconnection
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Motherboard Disconnection, Insert an opening pick: adım 1, 2 resimden 1. Motherboard Disconnection, Insert an opening pick: adım 1, 2 resimden 2.
    • Lay your eReader down so the back cover is facing up.
    • Insert the flat edge of an opening pick between the frame and the bottom left corner of the back cover.
    • Push the pick downwards at a slight angle until it slides under the back cover.
  2. Motherboard Disconnection, Release the bottom clips: adım 2, 3 resimden 1. Motherboard Disconnection, Release the bottom clips: adım 2, 3 resimden 2. Motherboard Disconnection, Release the bottom clips: adım 2, 3 resimden 3.
    • Slide the pick toward the bottom right corner to release the clips along the bottom edge.
  3. Motherboard Disconnection: adım 3, 2 resimden 1. Motherboard Disconnection: adım 3, 2 resimden 2.
    • Remove the pick and reinsert it under the bottom left corner.
    • Angle the pick flat under the back cover and rotate it around the bottom left corner to release its clips.
    • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
  4. Motherboard Disconnection, Release the left clips: adım 4, 3 resimden 1. Motherboard Disconnection, Release the left clips: adım 4, 3 resimden 2. Motherboard Disconnection, Release the left clips: adım 4, 3 resimden 3.
    • Slide the pick toward the top left corner to release the clips along the left edge.
  5. Motherboard Disconnection, Remove the back cover: adım 5, 3 resimden 1. Motherboard Disconnection, Remove the back cover: adım 5, 3 resimden 2. Motherboard Disconnection, Remove the back cover: adım 5, 3 resimden 3.
    • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
    • Grip the left edge of the back cover and lift it away from the eReader to release the remaining clips.
    • Remove the back cover.
    • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
  6. Motherboard Disconnection, Coating information: adım 6, 3 resimden 1. Motherboard Disconnection, Coating information: adım 6, 3 resimden 2. Motherboard Disconnection, Coating information: adım 6, 3 resimden 3.
    • The entire surface of the eReader's internals is covered in a thin, plastic-like waterproof coating. Keep the following in mind as you continue disassembly:
    • While this won't hurt your device, removing the coating compromises the device to potential water damage.
    • The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
    • The ZIF connector locking tabs are coated in a gel that can jam the hinge and keep the locking tab from completely unlocking. Make sure the tabs are completely upright before disconnecting any cables.
    • Depending on your repair, you might have to remove the coating from ZIF connectors and their cables.
  7. Motherboard Disconnection, Soften the battery connector coating: adım 7, 2 resimden 1. Motherboard Disconnection, Soften the battery connector coating: adım 7, 2 resimden 2.
  8. Motherboard Disconnection, Remove the battery connector coating: adım 8, 3 resimden 1. Motherboard Disconnection, Remove the battery connector coating: adım 8, 3 resimden 2. Motherboard Disconnection, Remove the battery connector coating: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the tip of a spudger to scrape up the coating along the white battery connector head—enough so you can grab clumps of it with pointed tweezers.
  9. Motherboard Disconnection: adım 9, 3 resimden 1. Motherboard Disconnection: adım 9, 3 resimden 2. Motherboard Disconnection: adım 9, 3 resimden 3.
    • Use pointed tweezers to peel off all of the coating around the battery connector head and its socket.
    • If the coating becomes too brittle and hard to peel off, reheat the connector and try again.
    • This is a meticulous process! Failure to remove enough of the coating could damage the plastic head during disconnection, so take your time!
  10. Motherboard Disconnection, Disconnect the battery: adım 10, 2 resimden 1. Motherboard Disconnection, Disconnect the battery: adım 10, 2 resimden 2.
    • Insert the point of a spudger under the edge of the battery connector head opposite of the cable.
    • There's a surface-mounted component close to the connector. Be careful not to touch it with your spudger!
    • Lift up the connector with the spudger to separate the rest of the coating and disconnect the battery.
    • During reassembly:
    • Inspect the connector head and its socket for any remaining coating that could prevent a good connection.
    • Peel off the coating, heating the area when the coating becomes too brittle.
    • It doesn't have to look pretty! You just need to remove enough coating so the connector head sits properly in its socket.
  11. Motherboard Disconnection, Unlock the power button ZIF connector: adım 11, 3 resimden 1. Motherboard Disconnection, Unlock the power button ZIF connector: adım 11, 3 resimden 2. Motherboard Disconnection, Unlock the power button ZIF connector: adım 11, 3 resimden 3.
    • There are surface-mounted components next to the power button ZIF connector. Follow the instructions carefully to avoid dislodging them.
    • Insert the tip of a spudger under the right side of the ZIF connector's black locking tab.
    • Lift up the locking tab with the spudger to unlock it.
    • The locking tab should be nearly vertical when unlocked. If not, gently push the tab forward to compress the gel and completely unlock the tab.
  12. Motherboard Disconnection, Soften the power button ZIF connector coating: adım 12, 1 resimden 1.
    • Apply a heated iOpener to the power button ZIF connector for 90 seconds to soften the coating.
    • Alternatively, you can use a hair dryer or a heat gun.
  13. Motherboard Disconnection, Disconnect the power button: adım 13, 3 resimden 1. Motherboard Disconnection, Disconnect the power button: adım 13, 3 resimden 2. Motherboard Disconnection, Disconnect the power button: adım 13, 3 resimden 3.
    • Because of the awkward angle, the next two steps requires some patience to avoid tearing the cable. Work slowly and apply heat regularly.
    • Use blunt nose tweezers to grip the power button cable close to the head
    • Twist the tweezers toward the top of the eReader to separate enough coating for the cable head to be angled above the battery.
    • Give your tweezers enough room so you don't puncture the battery as you twist them.
    • Gripping the tweezers closer to the tip can help you get a tighter hold on the cable.
  14. Motherboard Disconnection: adım 14, 3 resimden 1. Motherboard Disconnection: adım 14, 3 resimden 2. Motherboard Disconnection: adım 14, 3 resimden 3.
    • Grip the power button cable close to the head and pull it away from its ZIF connector slowly and steadily to separate the coating.
    • If the coating feels stubborn, reheat the connector and try again.
    • Keep pulling on the cable until it comes completely out of its socket.
    • Inspect the head of the cable and the ZIF connector for any remaining coating that could prevent a good connection.
    • Peel off the coating—heating the cable and the ZIF connector when the coating becomes too brittle.
    • It doesn't have to look pretty! You just need to remove enough coating to have the cable sit properly in its connector.
  15. Motherboard Disconnection, Unlock the digitizer cable ZIF connector: adım 15, 3 resimden 1. Motherboard Disconnection, Unlock the digitizer cable ZIF connector: adım 15, 3 resimden 2. Motherboard Disconnection, Unlock the digitizer cable ZIF connector: adım 15, 3 resimden 3.
    • Use the flat end of a spudger to lift up the locking tab on the digitizer cable ZIF connector.
  16. Motherboard Disconnection, Soften the digitizer cable coating: adım 16, 1 resimden 1.
    • Apply a heated iOpener to the digitizer cable ZIF connector for 90 seconds to soften the coating.
  17. Motherboard Disconnection, Disconnect the digitizer cable: adım 17, 3 resimden 1. Motherboard Disconnection, Disconnect the digitizer cable: adım 17, 3 resimden 2. Motherboard Disconnection, Disconnect the digitizer cable: adım 17, 3 resimden 3.
    • Use blunt nose tweezers to grip the digitizer cable close to the head and pull it away from its ZIF connector slowly and steadily to separate the coating.
  18. Motherboard Disconnection, Unlock the display ZIF connector: adım 18, 3 resimden 1. Motherboard Disconnection, Unlock the display ZIF connector: adım 18, 3 resimden 2. Motherboard Disconnection, Unlock the display ZIF connector: adım 18, 3 resimden 3.
    • There are surface-mounted components next to the display ZIF connector. Follow the instructions carefully to avoid dislodging them.
    • Insert the flat end of a spudger under the right side of the ZIF connector's black locking tab.
  19. Motherboard Disconnection, Soften the display connector coating: adım 19, 1 resimden 1.
    • Apply a heated iOpener to the display connector for 90 seconds to soften the coating.
  20. Motherboard Disconnection, Disconnect the display cable: adım 20, 2 resimden 1. Motherboard Disconnection, Disconnect the display cable: adım 20, 2 resimden 2.
    • Use blunt nose tweezers to grip the corner of the display cable closest to the charging port.
    • Pull the cable away from the ZIF connector slowly and steadily at a level angle to separate the coating at the corner.
    • If you're having trouble, try rocking the cable side-to-side while pulling.
    • Gripping the tweezers closer to the tip can help with getting a tighter hold on the cable.
  21. Motherboard Disconnection: adım 21, 2 resimden 1. Motherboard Disconnection: adım 21, 2 resimden 2.
    • Repeat the previous step for the other corner until the the cable comes completely out of its socket.
  22. Motherboard Disconnection: adım 22, 3 resimden 1. Motherboard Disconnection: adım 22, 3 resimden 2. Motherboard Disconnection: adım 22, 3 resimden 3.
    • Lift up the display cable and peel off any remaining coating holding it to the motherboard.
    • Inspect the head of the cable and the ZIF connectors for any remaining coating that could prevent a good connection.
    • It doesn't have to look pretty! You just need to remove enough coating to have the cable sit properly in the connector.
  23. Motherboard Disconnection, Unlock the backlight cable ZIF connector: adım 23, 3 resimden 1. Motherboard Disconnection, Unlock the backlight cable ZIF connector: adım 23, 3 resimden 2. Motherboard Disconnection, Unlock the backlight cable ZIF connector: adım 23, 3 resimden 3.
    • Lift the display cable out of the way of the backlight cable underneath.
    • Use the point of a spudger to lift up the blue locking tab on the backlight cable ZIF connector.
  24. Motherboard Disconnection, Soften the backlight connector coating: adım 24, 1 resimden 1.
    • Apply a heated iOpener to the backlight connector for 90 seconds to soften the coating.
  25. Motherboard Disconnection, Disconnect the backlight cable: adım 25, 2 resimden 1. Motherboard Disconnection, Disconnect the backlight cable: adım 25, 2 resimden 2.
    • Use blunt nose tweezers to grip the backlight cable close to its head and pull it away from its ZIF connector slowly and steadily to separate the coating.
Sonuç
Alex Diaz-Kokaisl
162.014 İtibar
769 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.418 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 114
