Ana içeriğe geç
Motion Computing LE1600 Bluetooth Module Replacement
Neye ihtiyacın var
  1. Motion Computing LE1600 Bluetooth Module Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device so the screen is facing down.
    FixBot'a Sor
    Yorum Ekle
  2. Motion Computing LE1600 Bluetooth Module Replacement: adım 2, 2 resimden 1. Motion Computing LE1600 Bluetooth Module Replacement: adım 2, 2 resimden 2.
    • Slide the battery lock switch next to the power slider to the unlocked position.
    FixBot'a Sor
    Yorum Ekle
  3. Motion Computing LE1600 Bluetooth Module Replacement: adım 3, 3 resimden 1. Motion Computing LE1600 Bluetooth Module Replacement: adım 3, 3 resimden 2. Motion Computing LE1600 Bluetooth Module Replacement: adım 3, 3 resimden 3.
    • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
    • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
    FixBot'a Sor
    Yorum Ekle
  4. Motion Computing LE1600 Bluetooth Module Replacement, Bluetooth Module: adım 4, 1 resimden 1.
    • Unscrew hard drive panel using a Phillips head #1 screwdriver.
    • (Our device was not given to us with a hard drive or a hard drive panel)
    FixBot'a Sor
    Yorum Ekle
  5. Motion Computing LE1600 Bluetooth Module Replacement: adım 5, 3 resimden 1. Motion Computing LE1600 Bluetooth Module Replacement: adım 5, 3 resimden 2. Motion Computing LE1600 Bluetooth Module Replacement: adım 5, 3 resimden 3.
    • Pull clear plastic tab to detach hard drive from tablet.
    FixBot'a Sor
    Yorum Ekle
  6. Motion Computing LE1600 Bluetooth Module Replacement: adım 6, 2 resimden 1. Motion Computing LE1600 Bluetooth Module Replacement: adım 6, 2 resimden 2.
    • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
    FixBot'a Sor
    Yorum Ekle
  7. Motion Computing LE1600 Bluetooth Module Replacement: adım 7, 1 resimden 1.
    • Pull the brown tabs to disconnect the white ribbon cable on the other side.
    FixBot'a Sor
    Yorum Ekle
  8. Motion Computing LE1600 Bluetooth Module Replacement: adım 8, 2 resimden 1. Motion Computing LE1600 Bluetooth Module Replacement: adım 8, 2 resimden 2.
    • Caution: do not pull on the wires, instead pull from the plastic connectors.
    • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
    FixBot'a Sor
    Yorum Ekle
  9. Motion Computing LE1600 Bluetooth Module Replacement: adım 9, 1 resimden 1.
    • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
    FixBot'a Sor
    Yorum Ekle
  10. Motion Computing LE1600 Bluetooth Module Replacement: adım 10, 1 resimden 1.
    • Using a spudger, press in the five tabs on the side where the battery was.
    • This should separate the two halves of the device. Carefully set the side with the display off to the side.
    FixBot'a Sor
    Yorum Ekle
  11. Motion Computing LE1600 Bluetooth Module Replacement: adım 11, 3 resimden 1. Motion Computing LE1600 Bluetooth Module Replacement: adım 11, 3 resimden 2. Motion Computing LE1600 Bluetooth Module Replacement: adım 11, 3 resimden 3.
    • Locate the Bluetooth board.
    • Disconnect the ribbon cable by pulling on the plastic connector.
    FixBot'a Sor
    Yorum Ekle
  12. Motion Computing LE1600 Bluetooth Module Replacement: adım 12, 2 resimden 1. Motion Computing LE1600 Bluetooth Module Replacement: adım 12, 2 resimden 2.
    • Unscrew the 4mm screw holding the board onto the tablet.
    • Lift the board out of the tablet and carefully set it aside.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Troy
44 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-14, Forte Spring 2012 Cal Poly, Team 15-14, Forte Spring 2012 üyesi
CPSU-FORTE-S12S15G14
5 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
thanks for the help
Lawrence V Lang - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 44
Her zaman: 2,846
