Ana içeriğe geç
Motion Computing LE1600 Button Assembly Replacement
Neye ihtiyacın var
  1. Motion Computing LE1600 Button Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device so the screen is facing down.
    FixBot'a Sor
    Yorum Ekle
  2. Motion Computing LE1600 Button Assembly Replacement: adım 2, 2 resimden 1. Motion Computing LE1600 Button Assembly Replacement: adım 2, 2 resimden 2.
    • Slide the battery lock switch next to the power slider to the unlocked position.
    FixBot'a Sor
    Yorum Ekle
  3. Motion Computing LE1600 Button Assembly Replacement: adım 3, 3 resimden 1. Motion Computing LE1600 Button Assembly Replacement: adım 3, 3 resimden 2. Motion Computing LE1600 Button Assembly Replacement: adım 3, 3 resimden 3.
    • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
    • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
    FixBot'a Sor
    Yorum Ekle
  4. Motion Computing LE1600 Button Assembly Replacement, Button Assembly: adım 4, 1 resimden 1.
    • Unscrew hard drive panel using a Phillips head #1 screwdriver.
    • (Our device was not given to us with a hard drive or a hard drive panel)
    FixBot'a Sor
    Yorum Ekle
  5. Motion Computing LE1600 Button Assembly Replacement: adım 5, 3 resimden 1. Motion Computing LE1600 Button Assembly Replacement: adım 5, 3 resimden 2. Motion Computing LE1600 Button Assembly Replacement: adım 5, 3 resimden 3.
    • Pull clear plastic tab to detach hard drive from tablet.
    FixBot'a Sor
    Yorum Ekle
  6. Motion Computing LE1600 Button Assembly Replacement: adım 6, 2 resimden 1. Motion Computing LE1600 Button Assembly Replacement: adım 6, 2 resimden 2.
    • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
    FixBot'a Sor
    Yorum Ekle
  7. Motion Computing LE1600 Button Assembly Replacement: adım 7, 1 resimden 1.
    • Pull the brown tabs to disconnect the white ribbon cable on the other side.
    FixBot'a Sor
    Yorum Ekle
  8. Motion Computing LE1600 Button Assembly Replacement: adım 8, 2 resimden 1. Motion Computing LE1600 Button Assembly Replacement: adım 8, 2 resimden 2.
    • Caution: do not pull on the wires, instead pull from the plastic connectors.
    • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
    FixBot'a Sor
    Yorum Ekle
  9. Motion Computing LE1600 Button Assembly Replacement: adım 9, 1 resimden 1.
    • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
    FixBot'a Sor
    Yorum Ekle
  10. Motion Computing LE1600 Button Assembly Replacement: adım 10, 2 resimden 1. Motion Computing LE1600 Button Assembly Replacement: adım 10, 2 resimden 2.
    • Using a spudger, press in the five tabs on the side where the battery was.
    • This should separate the two halves of the device. Carefully set the side with the motherboard off to the side.
    FixBot'a Sor
    Yorum Ekle
  11. Motion Computing LE1600 Button Assembly Replacement: adım 11, 2 resimden 1. Motion Computing LE1600 Button Assembly Replacement: adım 11, 2 resimden 2.
    • Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable.
    FixBot'a Sor
    Yorum Ekle
  12. Motion Computing LE1600 Button Assembly Replacement: adım 12, 2 resimden 1. Motion Computing LE1600 Button Assembly Replacement: adım 12, 2 resimden 2.
    • With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons.
    FixBot'a Sor
    Yorum Ekle
  13. Motion Computing LE1600 Button Assembly Replacement: adım 13, 2 resimden 1. Motion Computing LE1600 Button Assembly Replacement: adım 13, 2 resimden 2.
    • Remove the button board and replace.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Fred Wilby
71 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-14, Forte Spring 2012 Cal Poly, Team 15-14, Forte Spring 2012 üyesi
CPSU-FORTE-S12S15G14
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 22
Son 30 gün: 55
Her zaman: 2,333
