Ana içeriğe geç
Motorola 120c Microphone Replacement
Neye ihtiyacın var
  1. Motorola 120c Microphone Replacement, Battery: adım 1, 2 resimden 1. Motorola 120c Microphone Replacement, Battery: adım 1, 2 resimden 2.
    • Hold the phone and pull the back latch down towards the bottom.
    • Remove the back panel by releasing the latch and lifting from the top.
  2. Motorola 120c Microphone Replacement: adım 2, 3 resimden 1. Motorola 120c Microphone Replacement: adım 2, 3 resimden 2. Motorola 120c Microphone Replacement: adım 2, 3 resimden 3.
    • Remove the battery by pushing the bottom end towards the top, then lifting up.
  3. Motorola 120c Microphone Replacement, Motherboard: adım 3, 3 resimden 1. Motorola 120c Microphone Replacement, Motherboard: adım 3, 3 resimden 2. Motorola 120c Microphone Replacement, Motherboard: adım 3, 3 resimden 3.
    • Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
    • Once the screws are removed, simply lift the back panel off
  4. Motorola 120c Microphone Replacement: adım 4, 3 resimden 1. Motorola 120c Microphone Replacement: adım 4, 3 resimden 2. Motorola 120c Microphone Replacement: adım 4, 3 resimden 3.
    • Remove the motherboard by lifting it up and out.
  5. Motorola 120c Microphone Replacement, Microphone: adım 5, 2 resimden 1. Motorola 120c Microphone Replacement, Microphone: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers or fingers to remove the microphone.
    • Note that the keypad does not need to be removed to get to the microphone.
Sonuç
Megan Elrod
7 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-21, Amido Spring 2012 Cal Poly, Team 6-21, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S6G21
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 623
