Ana içeriğe geç
Motorola Atrix 4G LCD Replacement
Neye ihtiyacın var
  1. Motorola Atrix 4G LCD Replacement, Battery: adım 1, 1 resimden 1.
    • Pry the back cover off the back of the phone.
  2. Motorola Atrix 4G LCD Replacement: adım 2, 2 resimden 1. Motorola Atrix 4G LCD Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    • Insert a spudger into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G LCD Replacement, Antenna: adım 3, 2 resimden 1. Motorola Atrix 4G LCD Replacement, Antenna: adım 3, 2 resimden 2.
    T5 Torx Screwdriver
    $5.49
    • Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
    • Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
    • Use gentle force while unscrewing to avoid stripping the screws.
  4. Motorola Atrix 4G LCD Replacement: adım 4, 1 resimden 1.
    iFixit Opening Tool
    $1.99
  5. Motorola Atrix 4G LCD Replacement: adım 5, 2 resimden 1. Motorola Atrix 4G LCD Replacement: adım 5, 2 resimden 2.
    iFixit Opening Tool
    $1.99
    • Gently lift the tabs located at the top of the phone using an opening tool.
    • Gently lift the tab located at the bottom of the phone with the same tool.
    • Use an opening tool, not your fingers, because the plastic tabs are easily broken.
  6. Motorola Atrix 4G LCD Replacement: adım 6, 2 resimden 1. Motorola Atrix 4G LCD Replacement: adım 6, 2 resimden 2.
    iFixit Opening Tool
    $1.99
    • Insert an opening tool between the front and back of the case.
    • Slide the tool down the side of the phone.
    • Repeat the same process for the other side.
    • There should be a noticeable gap between the front and back cases. If not, repeat this step.
  7. Motorola Atrix 4G LCD Replacement: adım 7, 1 resimden 1.
    • Carefully lift the back case off the phone.
    • Do not completely separate the back case from the phone. The antenna is connected to both cases.
  8. Motorola Atrix 4G LCD Replacement: adım 8, 1 resimden 1.
    iFixit Opening Tool
    $1.99
    • Slide an opening tool beneath the antenna and lift straight up from the motherboard.
    • Lift straight upwards, not at an angle, to avoid damaging the socket underneath.
  9. Motorola Atrix 4G LCD Replacement: adım 9, 1 resimden 1.
    • Ease the antenna from out of its guide along the side of the phone
    • Remove the back case and the antenna from the phone.
    • The antenna is soldered to the back case. When reassembling, do not pull it with too much force.
  10. Motorola Atrix 4G LCD Replacement, Motherboard: adım 10, 2 resimden 1. Motorola Atrix 4G LCD Replacement, Motherboard: adım 10, 2 resimden 2.
    Spudger
    $3.99
    • Insert a spudger between the black plastic and the motherboard.
    • Lift upwards with the spudger to dislodge the board.
    • The motherboard should lift up easily. If the white rubber piece shifts, move it back to its original place.
  11. Motorola Atrix 4G LCD Replacement: adım 11, 1 resimden 1.
    Spudger
    $3.99
    • Disconnect the press connectors using a spudger.
    • If you are unfamiliar with using connectors, consult this guide.
  12. Motorola Atrix 4G LCD Replacement: adım 12, 1 resimden 1.
    Spudger
    $3.99
    • Lift the white latch on the ZIF connector using a spudger.
    • Gently pull the black ribbon down and away from the latch.
  13. Motorola Atrix 4G LCD Replacement: adım 13, 1 resimden 1.
    • There should be five distinct parts of the phone: the back cover, the back case, the front case, the battery, and the motherboard.
  14. Motorola Atrix 4G LCD Replacement, Screen: adım 14, 1 resimden 1.
    • Using a heat gun or a hair dryer on high heat, soften the adhesive securing the glass screen.
    • Direct the hot air along the front edges of the glass until the phone is warm to the touch.
  15. Motorola Atrix 4G LCD Replacement: adım 15, 3 resimden 1. Motorola Atrix 4G LCD Replacement: adım 15, 3 resimden 2. Motorola Atrix 4G LCD Replacement: adım 15, 3 resimden 3.
    • Using a plastic opening tool, carefully pry up the bottom of the display glass.
    • Slowly work your way around the phone, using the plastic opening tool to separate the glass from the phone.
    • As you work, the adhesive may cool and harden. You may need to heat up the glass again as you work your way around the screen.
  16. Motorola Atrix 4G LCD Replacement: adım 16, 2 resimden 1. Motorola Atrix 4G LCD Replacement: adım 16, 2 resimden 2.
    • Using a spudger, lift up the digitizer cable that is attached to the glass.
    • Be careful not to damage the cable. It is glued in place and hard to remove.
  17. Motorola Atrix 4G LCD Replacement: adım 17, 3 resimden 1. Motorola Atrix 4G LCD Replacement: adım 17, 3 resimden 2. Motorola Atrix 4G LCD Replacement: adım 17, 3 resimden 3.
    • Now that the cable has been removed you can slide it through the opening and detach the glass.
    • Be careful as you pull the cable through the opening. The cable is easily damaged.
    • Once the cable is pushed through the slot, the glass can be fully removed.
  18. Motorola Atrix 4G LCD Replacement, LCD: adım 18, 3 resimden 1. Motorola Atrix 4G LCD Replacement, LCD: adım 18, 3 resimden 2. Motorola Atrix 4G LCD Replacement, LCD: adım 18, 3 resimden 3.
    • With the glass removed you can now access the LCD screen.
    • Using a plastic opening tool, slide it in between LCD screen and the case of the phone and then pry it out carefully.
    • Slide the case opener tool along the side until the LCD pops out of the case.
    • Carefully guide the cables attached to the back of the LCD through the hole.
  19. Motorola Atrix 4G LCD Replacement: adım 19, 1 resimden 1.
    • The LCD is now ready to be replaced.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Paul Sullivan
238 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 9-42, Regan Spring 2012 Cal Poly, Team 9-42, Regan Spring 2012 üyesi
CPSU-REGAN-S12S9G42
6 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 7,079
