Ana içeriğe geç
Motorola Atrix HD Rear Chassis Disassembly
Neye ihtiyacın var
  1. Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: adım 1, 3 resimden 1. Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: adım 1, 3 resimden 2. Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: adım 1, 3 resimden 3.
    • Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
    • The adhesive strips may stay on the back cover or the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola Atrix HD Rear Chassis Disassembly: adım 2, 2 resimden 1. Motorola Atrix HD Rear Chassis Disassembly: adım 2, 2 resimden 2.
    • The back case portion may be removed after the battery has been removed.
    • Use the T5 Torx screwdriver to remove the 10 coarse-thread 5mm screws
    FixBot'a Sor
    Yorum Ekle
  3. Motorola Atrix HD Rear Chassis Disassembly: adım 3, 3 resimden 1. Motorola Atrix HD Rear Chassis Disassembly: adım 3, 3 resimden 2. Motorola Atrix HD Rear Chassis Disassembly: adım 3, 3 resimden 3.
    • Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
    • Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
    • The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Gabriel Agaman
597 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-8, Miles Fall 2015 UMass Dartmouth, Team 1-8, Miles Fall 2015 üyesi
UMASSD-MILES-F15S1G8
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 584
