Ana içeriğe geç
Motorola Buzz ic502 Keypad Replacement
Neye ihtiyacın var
  1. Motorola Buzz ic502 Keypad Replacement, Battery: adım 1, 3 resimden 1. Motorola Buzz ic502 Keypad Replacement, Battery: adım 1, 3 resimden 2. Motorola Buzz ic502 Keypad Replacement, Battery: adım 1, 3 resimden 3.
    • First flip the phone over.
    • Then find the back release circled in red.
  2. Motorola Buzz ic502 Keypad Replacement: adım 2, 2 resimden 1. Motorola Buzz ic502 Keypad Replacement: adım 2, 2 resimden 2.
    • Carefully remove the back using the release.
    • Lift from the bottom!
  3. Motorola Buzz ic502 Keypad Replacement: adım 3, 3 resimden 1. Motorola Buzz ic502 Keypad Replacement: adım 3, 3 resimden 2. Motorola Buzz ic502 Keypad Replacement: adım 3, 3 resimden 3.
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
  4. Motorola Buzz ic502 Keypad Replacement, Keypad: adım 4, 2 resimden 1. Motorola Buzz ic502 Keypad Replacement, Keypad: adım 4, 2 resimden 2.
    • Remove the plastic pieces with metal spudge
    • Under both are two screws, remove those as well.
    • Remove the other four screws on back of phone.
  5. Motorola Buzz ic502 Keypad Replacement: adım 5, 1 resimden 1.
    • Carefully lift screen as to not snap wire that connects it (shown is a version in which the screen has been fully removed).
    • Lift off keypad and replace.
Sonuç
Austin Quinn
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-6, Martin Fall 2016 UMass Dartmouth, Team 6-6, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 89
