Ana içeriğe geç
Motorola Buzz ic502 SIM card Replacement
  1. Motorola Buzz ic502 SIM card Replacement, Battery: adım 1, 3 resimden 1. Motorola Buzz ic502 SIM card Replacement, Battery: adım 1, 3 resimden 2. Motorola Buzz ic502 SIM card Replacement, Battery: adım 1, 3 resimden 3.
    • First flip the phone over.
    • Then find the back release circled in red.
  2. Motorola Buzz ic502 SIM card Replacement: adım 2, 2 resimden 1. Motorola Buzz ic502 SIM card Replacement: adım 2, 2 resimden 2.
    • Carefully remove the back using the release.
    • Lift from the bottom!
  3. Motorola Buzz ic502 SIM card Replacement: adım 3, 3 resimden 1. Motorola Buzz ic502 SIM card Replacement: adım 3, 3 resimden 2. Motorola Buzz ic502 SIM card Replacement: adım 3, 3 resimden 3.
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
  4. Motorola Buzz ic502 SIM card Replacement, SIM card: adım 4, 3 resimden 1. Motorola Buzz ic502 SIM card Replacement, SIM card: adım 4, 3 resimden 2. Motorola Buzz ic502 SIM card Replacement, SIM card: adım 4, 3 resimden 3.
    • The SIM card is located here
    • Carefully push the SIM card down from the top with your finger
    • Make sure to hold card from sides and do not touch the marked spot on card
Sonuç
Austin Quinn
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-6, Martin Fall 2016 UMass Dartmouth, Team 6-6, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 153
