Ana içeriğe geç
Motorola Buzz ic502 Screen and Speaker Replacement
Neye ihtiyacın var
  1. Motorola Buzz ic502 Screen and Speaker Replacement, Battery: adım 1, 3 resimden 1. Motorola Buzz ic502 Screen and Speaker Replacement, Battery: adım 1, 3 resimden 2. Motorola Buzz ic502 Screen and Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • First flip the phone over.
    • Then find the back release circled in red.
  2. Motorola Buzz ic502 Screen and Speaker Replacement: adım 2, 2 resimden 1. Motorola Buzz ic502 Screen and Speaker Replacement: adım 2, 2 resimden 2.
    • Carefully remove the back using the release.
    • Lift from the bottom!
  3. Motorola Buzz ic502 Screen and Speaker Replacement: adım 3, 3 resimden 1. Motorola Buzz ic502 Screen and Speaker Replacement: adım 3, 3 resimden 2. Motorola Buzz ic502 Screen and Speaker Replacement: adım 3, 3 resimden 3.
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
  4. Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: adım 4, 3 resimden 1. Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: adım 4, 3 resimden 2. Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: adım 4, 3 resimden 3.
    • Remove all six screws
    • The two top screws here
    • The two middle screws here.
    • And the two bottom screws here, they are covered by plastic pieces that first must be removed with the nylon Spudger.
  5. Motorola Buzz ic502 Screen and Speaker Replacement: adım 5, 3 resimden 1. Motorola Buzz ic502 Screen and Speaker Replacement: adım 5, 3 resimden 2. Motorola Buzz ic502 Screen and Speaker Replacement: adım 5, 3 resimden 3.
    • then carefully lift the front off the phone.
    • Marked wire will have to be solderd when re-connecting new screen
    • Speakers are connected to the screen here.
Sonuç
To reassemble your device, follow these instructions in reverse order, soldering wire onto new screen.
Austin Quinn
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-6, Martin Fall 2016 UMass Dartmouth, Team 6-6, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 87
