Ana içeriğe geç
Motorola C168 Front Panel Replacement
Neye ihtiyacın var
  1. Motorola C168 Front Panel Replacement, Battery: adım 1, 2 resimden 1. Motorola C168 Front Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Motorola C168 Front Panel Replacement: adım 2, 2 resimden 1. Motorola C168 Front Panel Replacement: adım 2, 2 resimden 2.
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Motorola C168 Front Panel Replacement, SIM Card: adım 3, 2 resimden 1. Motorola C168 Front Panel Replacement, SIM Card: adım 3, 2 resimden 2.
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Motorola C168 Front Panel Replacement, Front Panel: adım 4, 2 resimden 1. Motorola C168 Front Panel Replacement, Front Panel: adım 4, 2 resimden 2.
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
  5. Motorola C168 Front Panel Replacement: adım 5, 2 resimden 1. Motorola C168 Front Panel Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    Satın Al
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Wu
37 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-40, Regan Spring 2012 Cal Poly, Team 12-40, Regan Spring 2012 üyesi
CPSU-REGAN-S12S12G40
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 13
Her zaman: 1,031
