Ana içeriğe geç
Motorola C290 Antenna Replacement
  1. Motorola C290 Antenna Replacement, Battery: adım 1, 2 resimden 1. Motorola C290 Antenna Replacement, Battery: adım 1, 2 resimden 2.
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
  2. Motorola C290 Antenna Replacement: adım 2, 2 resimden 1. Motorola C290 Antenna Replacement: adım 2, 2 resimden 2.
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
  3. Motorola C290 Antenna Replacement, Antenna: adım 3, 3 resimden 1. Motorola C290 Antenna Replacement, Antenna: adım 3, 3 resimden 2. Motorola C290 Antenna Replacement, Antenna: adım 3, 3 resimden 3.
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
  4. Motorola C290 Antenna Replacement: adım 4, 2 resimden 1. Motorola C290 Antenna Replacement: adım 4, 2 resimden 2.
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Angelo Ballungay
79 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-28, Regan Spring 2010 Cal Poly, Team 24-28, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G28
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,980
