Ana içeriğe geç
Motorola C290 Logic Board Replacement
Neye ihtiyacın var
  1. Motorola C290 Logic Board Replacement, Battery: adım 1, 2 resimden 1. Motorola C290 Logic Board Replacement, Battery: adım 1, 2 resimden 2.
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
  2. Motorola C290 Logic Board Replacement: adım 2, 2 resimden 1. Motorola C290 Logic Board Replacement: adım 2, 2 resimden 2.
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
  3. Motorola C290 Logic Board Replacement, Antenna: adım 3, 3 resimden 1. Motorola C290 Logic Board Replacement, Antenna: adım 3, 3 resimden 2. Motorola C290 Logic Board Replacement, Antenna: adım 3, 3 resimden 3.
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
  4. Motorola C290 Logic Board Replacement: adım 4, 2 resimden 1. Motorola C290 Logic Board Replacement: adım 4, 2 resimden 2.
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
  5. Motorola C290 Logic Board Replacement, Logic Board: adım 5, 3 resimden 1. Motorola C290 Logic Board Replacement, Logic Board: adım 5, 3 resimden 2. Motorola C290 Logic Board Replacement, Logic Board: adım 5, 3 resimden 3.
    • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
    • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
    • Note: This will reveal a screw. Five screws should now be visible.
    • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
  6. Motorola C290 Logic Board Replacement: adım 6, 2 resimden 1. Motorola C290 Logic Board Replacement: adım 6, 2 resimden 2.
    • Insert the plastic opening tool in the groove at the top of the phone.
    • Rotate the tool to create an opening between the logic board cover and case.
  7. Motorola C290 Logic Board Replacement: adım 7, 2 resimden 1. Motorola C290 Logic Board Replacement: adım 7, 2 resimden 2.
    • Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
    • Remove logic board cover and set aside.
  8. Motorola C290 Logic Board Replacement: adım 8, 1 resimden 1.
    • Use the Spudger to detach the screen wire from the logic board.
  9. Motorola C290 Logic Board Replacement: adım 9, 3 resimden 1. Motorola C290 Logic Board Replacement: adım 9, 3 resimden 2. Motorola C290 Logic Board Replacement: adım 9, 3 resimden 3.
    • Insert the Spudger into the slot on the top of the logic board.
    • Gently pry to loosen the top of the logic board.
    • Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
    • Grab the top of the logic board and pull at an angle to remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Paul
22 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-28, Regan Spring 2010 Cal Poly, Team 24-28, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G28
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,388
