Ana içeriğe geç
Motorola C290 Screen Replacement
Neye ihtiyacın var
  1. Motorola C290 Screen Replacement, Outside Case removal: adım 1, 3 resimden 1. Motorola C290 Screen Replacement, Outside Case removal: adım 1, 3 resimden 2. Motorola C290 Screen Replacement, Outside Case removal: adım 1, 3 resimden 3.
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Motorola C290 Screen Replacement, Removing the front casing: adım 2, 2 resimden 1. Motorola C290 Screen Replacement, Removing the front casing: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Motorola C290 Screen Replacement, Disconnect the motherboard: adım 3, 2 resimden 1. Motorola C290 Screen Replacement, Disconnect the motherboard: adım 3, 2 resimden 2.
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  4. Motorola C290 Screen Replacement, Removing the motherboard/screen: adım 4, 3 resimden 1. Motorola C290 Screen Replacement, Removing the motherboard/screen: adım 4, 3 resimden 2. Motorola C290 Screen Replacement, Removing the motherboard/screen: adım 4, 3 resimden 3.
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
Sonuç
Angelo Ballungay
79 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-28, Regan Spring 2010 Cal Poly, Team 24-28, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G28
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,772
