Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide gives step-by-step instructions on repairing the speaker for a Motorola C290 cell phone.
  1. Flip open your Motorola C290. Remove rubber stoppers located around main screen using a push pin. This reveals four screws.
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Use a plastic opening tool to pry open a gap between the top cover and the face of the phone. Slide the plastic opening tool along gap and pry open case.
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Unclip circuit attachments located on back of screen circuit board using a Spudger. Unclip circuit attachments located on back of screen circuit board using a Spudger.
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  4. Insert the plastic opening tool between the metal screen components and the plastic frame at the corners. Firmly pry the screen components from the frame with a twisting motion You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
  5. Insert spudger underneath the speaker. Gently break the sticky seal between the phone case and speaker. Lift the speaker off the phone case.
    • Insert spudger underneath the speaker.
    • Gently break the sticky seal between the phone case and speaker.
    • Lift the speaker off the phone case.
    • Note: It will be necessary to destroy the seal to remove the speaker.
Sonuç
Philip Ybarra
27 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 24-28, Regan Spring 2010 Cal Poly, Team 24-28, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G28
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,109
