Giriş
Use this guide to replace the LCD in your Motorola C350.
Parçalar
Hiçbir parçaya gerek yok.
  1. Use your finger to press the button and free the device rear case.
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. slide the black button to free the battery so you can grab it with your other hand.
    • slide the black button to free the battery so you can grab it with your other hand.
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
    • Remove the 4 T6 Torx screws
    • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
    • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
    • Remove the two small metal clips keeping the cables safe.
    • Use a plastic spudger to pell off the two cables on the back side of the screen.
    • There are two very small connectors. Take care of them and replace them if they incidentally fall.
    • Use a plastic spudger to release the disconnected screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Vincent Monteil
6.197 İtibar
19 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 3
Her zaman: 454
