Ana içeriğe geç
Motorola C350 Front Case Replacement
  1. Motorola C350 Front Case Replacement, Rear case freeing: adım 1, 2 resimden 1. Motorola C350 Front Case Replacement, Rear case freeing: adım 1, 2 resimden 2.
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. Motorola C350 Front Case Replacement, Removing battery: adım 2, 1 resimden 1.
    • slide the black button to free the battery so you can grab it with your other hand.
  3. Motorola C350 Front Case Replacement, Separating the front case: adım 3, 2 resimden 1. Motorola C350 Front Case Replacement, Separating the front case: adım 3, 2 resimden 2.
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Vincent Monteil
6.975 İtibar
19 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 287
