Giriş
Use this guide to replace the upper speaker in your Motorola C350.
Neye ihtiyacın var
slide the black button to free the battery so you can grab it with your other hand.
You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
The upper speaker is kept in place by a metal plate.
Use a metal spudger to free the 3 clips on the back side
