Ana içeriğe geç
Motorola Cliq Audio Jack Replacement
Neye ihtiyacın var
  1. Motorola Cliq Audio Jack Replacement, Battery: adım 1, 2 resimden 1. Motorola Cliq Audio Jack Replacement, Battery: adım 1, 2 resimden 2.
    • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
  2. Motorola Cliq Audio Jack Replacement: adım 2, 2 resimden 1. Motorola Cliq Audio Jack Replacement: adım 2, 2 resimden 2.
    • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
  3. Motorola Cliq Audio Jack Replacement, Rear Casing: adım 3, 3 resimden 1. Motorola Cliq Audio Jack Replacement, Rear Casing: adım 3, 3 resimden 2. Motorola Cliq Audio Jack Replacement, Rear Casing: adım 3, 3 resimden 3.
    • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
    • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
  4. Motorola Cliq Audio Jack Replacement: adım 4, 1 resimden 1.
    • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
  5. Motorola Cliq Audio Jack Replacement: adım 5, 3 resimden 1. Motorola Cliq Audio Jack Replacement: adım 5, 3 resimden 2. Motorola Cliq Audio Jack Replacement: adım 5, 3 resimden 3.
    • Turn the phone over and slide out the keyboard.
    • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
    • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
    • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
  6. Motorola Cliq Audio Jack Replacement: adım 6, 1 resimden 1.
    • Carefully separate the back casing from the rest of the phone.
  7. Motorola Cliq Audio Jack Replacement: adım 7, 2 resimden 1. Motorola Cliq Audio Jack Replacement: adım 7, 2 resimden 2.
    • Gently pry ZIF connector upwards using the flat end of a spudger tool.
    • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
    • You may need adhesive to keep your power cable in place when reassembling your phone.
  8. Motorola Cliq Audio Jack Replacement: adım 8, 3 resimden 1. Motorola Cliq Audio Jack Replacement: adım 8, 3 resimden 2. Motorola Cliq Audio Jack Replacement: adım 8, 3 resimden 3.
    • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
    • The rear casing and the rest of the phone should now be completely separated.
  9. Motorola Cliq Audio Jack Replacement, Audio Jack: adım 9, 2 resimden 1. Motorola Cliq Audio Jack Replacement, Audio Jack: adım 9, 2 resimden 2.
    • Gently insert the plastic spudger into the audio jack and pry upwards.
  10. Motorola Cliq Audio Jack Replacement: adım 10, 2 resimden 1. Motorola Cliq Audio Jack Replacement: adım 10, 2 resimden 2.
    • Using your fingers, lift the audio jack out of its bracket.
Sonuç
Tony Tran
64 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-42, Amido Spring 2013 Cal Poly, Team 10-42, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G42
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 522
