Ana içeriğe geç
Motorola DROID MAXX Full Screen Replacement
Neye ihtiyacın var
  1. Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: adım 1, 3 resimden 1. Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: adım 1, 3 resimden 2. Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: adım 1, 3 resimden 3.
    • Find the volume buttons located on the side of the Droid Maxx.
    • Take the plastic opening tool and insert it into the gap between the volume buttons and the case.
    • Using the flat tip of the plastic opening tool, press firmly against the case until you hear a “snap” sound.
    • Remove the buttons carefully. Do not bend or force the part since it also serves as a tray for placing a SIM Card.
  2. Motorola DROID MAXX Full Screen  Replacement: adım 2, 3 resimden 1. Motorola DROID MAXX Full Screen  Replacement: adım 2, 3 resimden 2. Motorola DROID MAXX Full Screen  Replacement: adım 2, 3 resimden 3.
    • Using the flat tip of the plastic opening tool, press firmly against the case until you hear an audible click.
    • Once the top part of the case is separated from the frame, grip the bottom part of the rubber case with your finger and slide the case down to remove it completely.
  3. Motorola DROID MAXX Full Screen  Replacement: adım 3, 3 resimden 1. Motorola DROID MAXX Full Screen  Replacement: adım 3, 3 resimden 2. Motorola DROID MAXX Full Screen  Replacement: adım 3, 3 resimden 3.
    • Using the Torx T5 Screwdriver, carefully remove all of the screws in the motherboard.
    • There are 8 black screws: 4 at the top and 4 at the bottom of the motherboard.
    • There are 2 silver screws on the side: 1 at the bottom and 1 in the middle.
    • Use either a T3 (Ultra) or T4 (MAXX) to remove the single screw securing the camera housing.
    • Using the plastic opening tool, gently lift the two tabs in the upper plastic cover that surrounds the camera to release the cover.
  4. Motorola DROID MAXX Full Screen  Replacement: adım 4, 3 resimden 1. Motorola DROID MAXX Full Screen  Replacement: adım 4, 3 resimden 2. Motorola DROID MAXX Full Screen  Replacement: adım 4, 3 resimden 3.
    • Carefully disconnect the ribbon cable from the motherboard and front screen.
    • Place the ribbon cable under the orange tape during reassembly.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jordan
227 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Harley Spring 2017 IUPUI, Team S2-G4, Harley Spring 2017 üyesi
IUPUI-HARLEY-S17S2G4
4 Üyeler
1 Kılavuz yazıldı
2 Yorum
Where can I purchase the screen replacement for the droid maxx
Zachary lawson - Yanıt
That 3mm screw is a ##&&%. BE VERY CAREFUL WITH IT! I haven’t figured out how to best loosen it yet; maybe small turn bursts so you don’t break the tines?
Ron Herren - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 6,500
