Ana içeriğe geç
Motorola DROID RAZR MAXX Camera Cover Replacement
Neye ihtiyacın var
  1. Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: adım 1, 2 resimden 1. Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: adım 1, 2 resimden 2.
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola DROID RAZR MAXX Camera Cover Replacement: adım 2, 2 resimden 1. Motorola DROID RAZR MAXX Camera Cover Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola DROID RAZR MAXX Camera Cover Replacement: adım 3, 3 resimden 1. Motorola DROID RAZR MAXX Camera Cover Replacement: adım 3, 3 resimden 2. Motorola DROID RAZR MAXX Camera Cover Replacement: adım 3, 3 resimden 3.
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola DROID RAZR MAXX Camera Cover Replacement: adım 4, 1 resimden 1.
    • Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
    • Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Govind
130 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 14-6, Leahy Fall 2014 USF Tampa, Team 14-6, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G6
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 18
Her zaman: 745
