Ana içeriğe geç
Motorola Defy LCD Replacement
Neye ihtiyacın var
  1. Motorola Defy LCD Replacement, Rear Case: adım 1, 1 resimden 1.
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy LCD Replacement: adım 2, 2 resimden 1. Motorola Defy LCD Replacement: adım 2, 2 resimden 2.
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy LCD Replacement, Battery: adım 3, 1 resimden 1.
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy LCD Replacement, Midframe: adım 4, 1 resimden 1.
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy LCD Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy LCD Replacement, Motherboard: adım 6, 2 resimden 1. Motorola Defy LCD Replacement, Motherboard: adım 6, 2 resimden 2.
    • Use metal spudger to pry off the middle yellow flap carefully.
  7. Motorola Defy LCD Replacement: adım 7, 3 resimden 1. Motorola Defy LCD Replacement: adım 7, 3 resimden 2. Motorola Defy LCD Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers again to pry off the second yellow flap carefully.
  8. Motorola Defy LCD Replacement: adım 8, 1 resimden 1.
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
  9. Motorola Defy LCD Replacement, Removing the LCD: adım 9, 2 resimden 1. Motorola Defy LCD Replacement, Removing the LCD: adım 9, 2 resimden 2.
    • Stick the metal spudger in between the LCD screen and the case of the phone.
    • Remove the LCD screen and replace with a new one.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ebrahem AlRayes
183 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 14-2, Leahy Fall 2014 USF Tampa, Team 14-2, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G2
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 1,249
