Ana içeriğe geç
Motorola Defy Motherboard Replacement
Neye ihtiyacın var
  1. Motorola Defy Motherboard Replacement, Rear Case: adım 1, 1 resimden 1.
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola Defy Motherboard Replacement: adım 2, 2 resimden 1. Motorola Defy Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola Defy Motherboard Replacement, Battery: adım 3, 1 resimden 1.
    • Use a plastic opening tool to pry the battery out of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola Defy Motherboard Replacement, Midframe: adım 4, 1 resimden 1.
    • Unscrew the two silver screws located at the top of the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola Defy Motherboard Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola Defy Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. Motorola Defy Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    • Use metal spudger to pry off the middle yellow flap carefully.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola Defy Motherboard Replacement: adım 7, 3 resimden 1. Motorola Defy Motherboard Replacement: adım 7, 3 resimden 2. Motorola Defy Motherboard Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers again to pry off the second yellow flap carefully.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola Defy Motherboard Replacement: adım 8, 1 resimden 1.
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Romario
102 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 14-2, Leahy Fall 2014 USF Tampa, Team 14-2, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G2
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 1,183
