Ana içeriğe geç
Motorola Defy Motherboard Replacement
Neye ihtiyacın var
  1. Motorola Defy Motherboard Replacement, Rear Case: adım 1, 1 resimden 1.
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy Motherboard Replacement: adım 2, 2 resimden 1. Motorola Defy Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy Motherboard Replacement, Battery: adım 3, 1 resimden 1.
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy Motherboard Replacement, Midframe: adım 4, 1 resimden 1.
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy Motherboard Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. Motorola Defy Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    • Use metal spudger to pry off the middle yellow flap carefully.
  7. Motorola Defy Motherboard Replacement: adım 7, 3 resimden 1. Motorola Defy Motherboard Replacement: adım 7, 3 resimden 2. Motorola Defy Motherboard Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers again to pry off the second yellow flap carefully.
  8. Motorola Defy Motherboard Replacement: adım 8, 1 resimden 1.
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
Sonuç
Romario
102 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 14-2, Leahy Fall 2014 USF Tampa, Team 14-2, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G2
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 871
