Ana içeriğe geç
Motorola Defy Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Motorola Defy Rear Facing Camera Replacement, Rear Case: adım 1, 1 resimden 1.
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy Rear Facing Camera Replacement: adım 2, 2 resimden 1. Motorola Defy Rear Facing Camera Replacement: adım 2, 2 resimden 2.
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy Rear Facing Camera Replacement, Battery: adım 3, 1 resimden 1.
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy Rear Facing Camera Replacement, Midframe: adım 4, 1 resimden 1.
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy Rear Facing Camera Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy Rear Facing Camera Replacement, Rear Facing Camera: adım 6, 2 resimden 1. Motorola Defy Rear Facing Camera Replacement, Rear Facing Camera: adım 6, 2 resimden 2.
    • Start to pry around the bottom of the camera module with the metal spudger and replace with the new camera module.
    • Be careful of the pins that are connected to the camera module on the bottom.
Sonuç
Morgan Roark
325 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-2, Leahy Fall 2014 USF Tampa, Team 14-2, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G2
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 422
