Ana içeriğe geç
Motorola Defy XT Battery Replacement
Neye ihtiyacın var
  1. Motorola Defy XT Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Battery Replacement: adım 2, 1 resimden 1.
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT Battery Replacement: adım 3, 1 resimden 1.
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dorian Capps
64 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G22
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
There isn't really much need for guidance on replacing the battery, but it would be helpful if you could provide some details on how long it takes for the first charge after replacement. I connected my charger after replacing the battery and it only lights up the back/menu/home keys below the screen - no indication of battery charging etc. and the phone cannot be powered yet. It's been charging for well over half an hour. Any advice?
shaunschon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,680
