Ana içeriğe geç
Motorola Defy XT Screen Replacement
Neye ihtiyacın var
  1. Motorola Defy XT Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Screen Replacement: adım 2, 1 resimden 1.
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT Screen Replacement: adım 3, 1 resimden 1.
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT Screen Replacement, SD Card: adım 4, 1 resimden 1.
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
  5. Motorola Defy XT Screen Replacement, Screen: adım 5, 2 resimden 1. Motorola Defy XT Screen Replacement, Screen: adım 5, 2 resimden 2.
    • Use the Torx T4 screwdriver to remove the six 3 mm screws from the back case.
  6. Motorola Defy XT Screen Replacement: adım 6, 1 resimden 1.
    • Use the plastic opening tool to pop the volume buttons off from the side of the phone.
  7. Motorola Defy XT Screen Replacement: adım 7, 1 resimden 1.
    • Wedge the plastic opening tool between the plastic layer and the shiny front cover.
  8. Motorola Defy XT Screen Replacement: adım 8, 1 resimden 1.
    • Slide the plastic opening tool along the edge, wedging the the two pieces apart.
    • Potential for device damage: Do not completely separate the two pieces; there are still internal components that need to be disconnected.
  9. Motorola Defy XT Screen Replacement: adım 9, 2 resimden 1. Motorola Defy XT Screen Replacement: adım 9, 2 resimden 2.
    • Slide the screen out and disconnect the ribbon cable connecting the display to the motherboard by pulling straight outward.
    • Potential for device damage: Be careful when sliding out the screen because the front case and the motherboard are still connected by two other ribbon cables.
  10. Motorola Defy XT Screen Replacement: adım 10, 2 resimden 1. Motorola Defy XT Screen Replacement: adım 10, 2 resimden 2.
    • Set the old screen aside and replace it with your new screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Oscar Camacho
89 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G22
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 3,142
