Ana içeriğe geç
Motorola Droid 2 Camera Assembly Replacement
Neye ihtiyacın var
  1. Motorola Droid 2 Camera Assembly Replacement, Battery: adım 1, 3 resimden 1. Motorola Droid 2 Camera Assembly Replacement, Battery: adım 1, 3 resimden 2. Motorola Droid 2 Camera Assembly Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the battery cover toward the bottom edge of the phone.
    • Remove the battery cover from the rear of the phone.
  2. Motorola Droid 2 Camera Assembly Replacement: adım 2, 2 resimden 1. Motorola Droid 2 Camera Assembly Replacement: adım 2, 2 resimden 2.
    • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
    • Remove the battery from the Droid 2.
  3. Motorola Droid 2 Camera Assembly Replacement, Rear Case: adım 3, 2 resimden 1. Motorola Droid 2 Camera Assembly Replacement, Rear Case: adım 3, 2 resimden 2.
    • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
    • Peel the ribbon off the phone.
  4. Motorola Droid 2 Camera Assembly Replacement: adım 4, 1 resimden 1.
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  5. Motorola Droid 2 Camera Assembly Replacement: adım 5, 1 resimden 1.
    • Use the tip of a spudger to remove the camera bezel stuck to the rear case.
  6. Motorola Droid 2 Camera Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  7. Motorola Droid 2 Camera Assembly Replacement: adım 7, 1 resimden 1.
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  8. Motorola Droid 2 Camera Assembly Replacement: adım 8, 1 resimden 1.
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  9. Motorola Droid 2 Camera Assembly Replacement: adım 9, 2 resimden 1. Motorola Droid 2 Camera Assembly Replacement: adım 9, 2 resimden 2.
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  10. Motorola Droid 2 Camera Assembly Replacement: adım 10, 2 resimden 1. Motorola Droid 2 Camera Assembly Replacement: adım 10, 2 resimden 2.
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
    • At this point, the button covers on the side of the phone are free and may fall out if you tip the phone upside down.
  11. Motorola Droid 2 Camera Assembly Replacement, Speaker: adım 11, 1 resimden 1.
    • Carefully lift the speaker/antenna assembly up and out of the phone.
    • If you are re-assembling your phone, insert any power, camera, or volume buttons that may have fallen out at this point.
  12. Motorola Droid 2 Camera Assembly Replacement, Motherboard: adım 12, 3 resimden 1. Motorola Droid 2 Camera Assembly Replacement, Motherboard: adım 12, 3 resimden 2. Motorola Droid 2 Camera Assembly Replacement, Motherboard: adım 12, 3 resimden 3.
    • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
    • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
  13. Motorola Droid 2 Camera Assembly Replacement: adım 13, 1 resimden 1.
    • Peel the black rubber sheet covering the side button and display ribbon connectors on the motherboard.
  14. Motorola Droid 2 Camera Assembly Replacement: adım 14, 1 resimden 1.
    • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
  15. Motorola Droid 2 Camera Assembly Replacement: adım 15, 1 resimden 1.
    • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
  16. Motorola Droid 2 Camera Assembly Replacement: adım 16, 1 resimden 1.
    • Use the flat end of a spudger to remove the small black plastic piece stuck to the battery connector.
  17. Motorola Droid 2 Camera Assembly Replacement: adım 17, 1 resimden 1.
    • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
    • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
  18. Motorola Droid 2 Camera Assembly Replacement: adım 18, 1 resimden 1.
    • Carefully lift the motherboard from the front case and lay it next to the Droid 2, minding the keypad connector that is still attached.
    • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
    • Remove the motherboard from the Droid 2.
  19. Motorola Droid 2 Camera Assembly Replacement, Camera Assembly: adım 19, 2 resimden 1. Motorola Droid 2 Camera Assembly Replacement, Camera Assembly: adım 19, 2 resimden 2.
    • Orient the motherboard so that the camera lens is face down.
    • Disconnect the camera connector from its socket by prying it straight up with a spudger.
    • Remove the camera assembly from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 8,592
