Giriş
Follow this guide to replace your Droid 2's broken or malfunctioning motherboard.
Neye ihtiyacın var
Slide the battery cover toward the bottom edge of the phone.
Remove the battery cover from the rear of the phone.
Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
Peel the ribbon off the phone.
Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
6 farklı kişi bu kılavuzu tamamladı.
