Ana içeriğe geç
Motorola Droid 2 Rear Case Replacement
Neye ihtiyacın var
  1. Motorola Droid 2 Rear Case Replacement, Battery: adım 1, 3 resimden 1. Motorola Droid 2 Rear Case Replacement, Battery: adım 1, 3 resimden 2. Motorola Droid 2 Rear Case Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the battery cover toward the bottom edge of the phone.
    • Remove the battery cover from the rear of the phone.
  2. Motorola Droid 2 Rear Case Replacement: adım 2, 2 resimden 1. Motorola Droid 2 Rear Case Replacement: adım 2, 2 resimden 2.
    • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
    • Remove the battery from the Droid 2.
  3. Motorola Droid 2 Rear Case Replacement, Rear Case: adım 3, 2 resimden 1. Motorola Droid 2 Rear Case Replacement, Rear Case: adım 3, 2 resimden 2.
    • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
    • Peel the ribbon off the phone.
  4. Motorola Droid 2 Rear Case Replacement: adım 4, 1 resimden 1.
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  5. Motorola Droid 2 Rear Case Replacement: adım 5, 1 resimden 1.
    • Use the tip of a spudger to remove the camera bezel stuck to the rear case.
  6. Motorola Droid 2 Rear Case Replacement: adım 6, 1 resimden 1.
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  7. Motorola Droid 2 Rear Case Replacement: adım 7, 1 resimden 1.
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  8. Motorola Droid 2 Rear Case Replacement: adım 8, 1 resimden 1.
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  9. Motorola Droid 2 Rear Case Replacement: adım 9, 2 resimden 1. Motorola Droid 2 Rear Case Replacement: adım 9, 2 resimden 2.
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  10. Motorola Droid 2 Rear Case Replacement: adım 10, 2 resimden 1. Motorola Droid 2 Rear Case Replacement: adım 10, 2 resimden 2.
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
    • At this point, the button covers on the side of the phone are free and may fall out if you tip the phone upside down.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 6,167
