Ana içeriğe geç
Motorola Droid 4 MicroSD/SIM Card Reader Replacement
Neye ihtiyacın var
  1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing Rear Panel: adım 1, 3 resimden 1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing Rear Panel: adım 1, 3 resimden 2. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing Rear Panel: adım 1, 3 resimden 3.
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Battery: adım 2, 1 resimden 1.
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
  3. Motorola Droid 4 MicroSD/SIM Card Reader Replacement: adım 3, 2 resimden 1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    T5 Torx Screwdriver
    $5.49
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
  4. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Camera Cover Removal: adım 4, 3 resimden 1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Camera Cover Removal: adım 4, 3 resimden 2. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Camera Cover Removal: adım 4, 3 resimden 3.
    • Using the blue plastic opening tool, pry off the thin plastic camera cover.
    • The plastic cover is fragile, so proceed carefully.
  5. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Screws: adım 5, 2 resimden 1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Screws: adım 5, 2 resimden 2.
    • Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
    • The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
  6. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Bezel: adım 6, 3 resimden 1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Bezel: adım 6, 3 resimden 2. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Bezel: adım 6, 3 resimden 3.
    • Insert the spudger between the rear bezel and the main housing.
    • The bezel is fragile, so proceed carefully.
    • Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Pry the bezel free.
    • Be careful of the adhesive that holds the bezel to the main housing. Prying too hard may damage your phone.
  7. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing screws: adım 7, 2 resimden 1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing screws: adım 7, 2 resimden 2.
    • Remove the 12 screws holding the housing in place using a T5 Torx screwdriver.
    • Follow the red circles, indicated in the picture, to locate the screws.
    • The 12 screws are (silver) philips 2.5mm
  8. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separation of the Housing from the Motherboard: adım 8, 3 resimden 1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separation of the Housing from the Motherboard: adım 8, 3 resimden 2. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separation of the Housing from the Motherboard: adım 8, 3 resimden 3.
    • Separate the housing from the motherboard.
    • Be careful while separating the housing. The power and volume buttons are easily separated from the housing and can be damaged.
  9. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, MicroSD/SIM Card Reader: adım 9, 3 resimden 1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, MicroSD/SIM Card Reader: adım 9, 3 resimden 2. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, MicroSD/SIM Card Reader: adım 9, 3 resimden 3.
    • Once the Motherboard Housing is removed the complete Micro SD/SIM card reader is exposed, as indicated by the picture.
    • Remove the two screws that attach the reader to the Motherboard. The locations of the screws are indicated in the picture.
  10. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separate the reader from the motherboard: adım 10, 3 resimden 1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separate the reader from the motherboard: adım 10, 3 resimden 2. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separate the reader from the motherboard: adım 10, 3 resimden 3.
    • Using the spudger, pry off the Reader.
    • Be careful while removing the Reader. The connection to the motherboard is composed of small pins.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Javier
533 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-1, Mcgee Fall 2014 USF Tampa, Team 5-1, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G1
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,796
