Ana içeriğe geç
Motorola Droid 4 Rear Bezel Replacement
Neye ihtiyacın var
  1. Motorola Droid 4 Rear Bezel Replacement, Removing Rear Panel: adım 1, 3 resimden 1. Motorola Droid 4 Rear Bezel Replacement, Removing Rear Panel: adım 1, 3 resimden 2. Motorola Droid 4 Rear Bezel Replacement, Removing Rear Panel: adım 1, 3 resimden 3.
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 Rear Bezel Replacement, Battery: adım 2, 1 resimden 1.
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
  3. Motorola Droid 4 Rear Bezel Replacement: adım 3, 2 resimden 1. Motorola Droid 4 Rear Bezel Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    T5 Torx Screwdriver
    $5.49
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
  4. Motorola Droid 4 Rear Bezel Replacement, Camera Cover Removal: adım 4, 3 resimden 1. Motorola Droid 4 Rear Bezel Replacement, Camera Cover Removal: adım 4, 3 resimden 2. Motorola Droid 4 Rear Bezel Replacement, Camera Cover Removal: adım 4, 3 resimden 3.
    • Using the blue plastic opening tool, pry off the thin plastic camera cover.
    • The plastic cover is fragile, so proceed carefully.
  5. Motorola Droid 4 Rear Bezel Replacement, Remove Screws: adım 5, 2 resimden 1. Motorola Droid 4 Rear Bezel Replacement, Remove Screws: adım 5, 2 resimden 2.
    • Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
    • The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
  6. Motorola Droid 4 Rear Bezel Replacement, Remove Bezel: adım 6, 3 resimden 1. Motorola Droid 4 Rear Bezel Replacement, Remove Bezel: adım 6, 3 resimden 2. Motorola Droid 4 Rear Bezel Replacement, Remove Bezel: adım 6, 3 resimden 3.
    • Insert the spudger between the rear bezel and the main housing.
    • The bezel is fragile, so proceed carefully.
    • Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Pry the bezel free.
    • Be careful of the adhesive that holds the bezel to the main housing. Prying too hard may damage your phone.
Sonuç
Cheriann
156 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 5-1, Mcgee Fall 2014 USF Tampa, Team 5-1, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G1
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 564
