Ana içeriğe geç
Motorola Droid 4 SIM Card Replacement
Neye ihtiyacın var
  1. Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: adım 1, 3 resimden 1. Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: adım 1, 3 resimden 2. Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: adım 1, 3 resimden 3.
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: adım 2, 3 resimden 1. Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: adım 2, 3 resimden 2. Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using tweezers or your finger, lift the rubber SIM card cover to expose the card itself.
  3. Motorola Droid 4 SIM Card Replacement, Removing SIM card: adım 3, 3 resimden 1. Motorola Droid 4 SIM Card Replacement, Removing SIM card: adım 3, 3 resimden 2. Motorola Droid 4 SIM Card Replacement, Removing SIM card: adım 3, 3 resimden 3.
    • While holding the cover open, use your finger to press and slide out the SIM card.
    • When reinserting the SIM card, make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
  4. Motorola Droid 4 SIM Card Replacement, Insert new SIM card: adım 4, 3 resimden 1. Motorola Droid 4 SIM Card Replacement, Insert new SIM card: adım 4, 3 resimden 2. Motorola Droid 4 SIM Card Replacement, Insert new SIM card: adım 4, 3 resimden 3.
    • Follow the same steps in the opposite order to install the new SIM card.
    • Make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Javier
533 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-1, Mcgee Fall 2014 USF Tampa, Team 5-1, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G1
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 3,859
