Ana içeriğe geç
Motorola Droid Bionic LCD Replacement
Neye ihtiyacın var
  1. Motorola Droid Bionic LCD Replacement, LCD: adım 1, 1 resimden 1.
    • Remove the back battery cover.
  2. Motorola Droid Bionic LCD Replacement: adım 2, 1 resimden 1.
    • Remove the battery
  3. Motorola Droid Bionic LCD Replacement: adım 3, 2 resimden 1. Motorola Droid Bionic LCD Replacement: adım 3, 2 resimden 2.
    • Remove the 11 T4 Torx Screws
    • Next, remove the information sticker.
  4. Motorola Droid Bionic LCD Replacement: adım 4, 2 resimden 1. Motorola Droid Bionic LCD Replacement: adım 4, 2 resimden 2.
    • Using a plastic removal tool, work around the edges of the back housing.
    • Lift off the back housing.
  5. Motorola Droid Bionic LCD Replacement: adım 5, 3 resimden 1. Motorola Droid Bionic LCD Replacement: adım 5, 3 resimden 2. Motorola Droid Bionic LCD Replacement: adım 5, 3 resimden 3.
    • Remove the two silver T4 screws securing the SIM tray.
    • Carefully lift the SIM tray to disconnect it from the board.
    • Carefully remove the plastic spacer beneath by lifting gently in the center with a plastic removal tool.
    • Then, using a plastic removal tool, disconnect the speaker & front facing camera assembly from the board. The speaker is attached with adhesive, so be careful not to rip the flex cable.
  6. Motorola Droid Bionic LCD Replacement: adım 6, 1 resimden 1.
    • Disconnect the 2 digitizer connectors using a plastic removal tool.
    • Then disconnect the LCD connector
  7. Motorola Droid Bionic LCD Replacement: adım 7, 2 resimden 1. Motorola Droid Bionic LCD Replacement: adım 7, 2 resimden 2.
    • The board is now free from all connections. Carefully lift from the top and remove the board.
  8. Motorola Droid Bionic LCD Replacement: adım 8, 2 resimden 1. Motorola Droid Bionic LCD Replacement: adım 8, 2 resimden 2.
    • Carefully peel the two flex cables from the back housing of the LCD. Be exceptionally careful during this process, as those flex cables can be easily ripped.
    • With the flex cables out of the way, you can now use a plastic opening tool to carefully pry the old LCD loose and out of the display.
    • If you're installing a new LCD, simply add it now and follow these instructions in reverse to complete the installation.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Taylor
244 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 1,861
